F22 Epp/Depron Parkjet made with Blue Core 1/4" foam
by animan | June 26, 2012 | (9) Posted in Projects
After watching the build video on the Flite Test You Tube channel, I decided to build one. I used 1/4" Blue Core foam (I removed the plastic sheet off the sides first). I used balsa wood on all the exposed edges and bass wood for the wing strengtheners.  I am not fully satisfied with the performance of the power system. After many years of RC electric designs (35 years), I always notice the run times of the power system goes down on a pusher style arrangement. I am now going to move the motor/prop to the back side of the prop slot and make the system a "tractor  pull" and see if this improves my performance numbers. I will upload a new video if this works.  I also decided to use a KM2 airfoil on the wing to improve flight performance (which it did).
schraut5 on July 1, 2012
Good work! Looks really great. Good tips too!
animan on July 1, 2012
Thanks for the complements.
WizzyWiggs on July 9, 2012
Awesome job!
kc2pxp on July 9, 2012
Nice video. I just built an F-22 and I used a forward facing motor like to you did and it works great. I plan to build another F-22 using the air foil method that you used. Thanks for the great video and the tips!
Bbjen on June 26, 2012
Nice one!
animan on June 26, 2012
Thanks!
F22 Epp/Depron Parkjet made with Blue Core 1/4" fo...
