Have you ever had an o-ring that just wouldn't fit?
Luckily I found a solution to this annoying problem all you have to do is take a clamp, fit the o-ring onto the end of the clamp and stretch out the o-ring.
The pictures below show how to do it.
I hope this forum was helpful.
1: Find a clamp
2: attach o-ring to clamp(might have to hold onto the o ring until you have started to stretch)
3: Stretch the o-ring until it is nearly impossible to pull the handle on the clamp.
If you follow these steps you can have a stretched o-ring in no time at all!!
