On the diagram, the module receiver is placed in this direction :
If you want change the frequency : (Dot not use the Pin 10, 11, 12 because it's the antenna connector)
UPDATE : I PUT NEW SWITCH FOR CHANGE THE FREQUENCY !!!
Val.
Val.
Val.
How would you get RSSI out of this receiver? which pin would you use?
Comment if that's what you thought
