I definitely recommend this excellent and super fun aircraft. Why? go ahead, after reading this e-flite convergence vtol review you will know the reason.
Unboxing
As you see the above image, there are one boboy convergence vtol BNF, two pair propellers, two vertical fins and one user manual in the foam box. Before you flight, need full range at least 6 channels transmitter and 2200-3000mAh 3s lipo battery. If you need FPV system, video transmitter and FPV camera are required. In general, look like very simple to ready to fly. The quality of the E-flite convergence vtol feels pretty good as is expected from Horizon Hobby.
Assembly
Next step is assemble all the parts, assembling the convergence VTOL is quick and easy as following.
Install the vertical fins
Install the vertical fins on the fuselage using two screws per side.
Install propellers
The main propellers are labelled near the hub with an “R” and an “L” to show on which side they should be installed. Install the propeller nut on the collet. Use a small screwdriver or hex wrench through the hole in the propeller nut to tighten.
Install battery
Install the fully charged battery in the battery compartment. Secure using the hook and loop strap. Connect the battery to the flight controller. Refer to the Center of Gravity section to ensure the model balances at the recommended CG.
Install FPV system
Items required for FPV system installation, there are camera,video transmiter,antenna and video monitor with headset or goggles.
Installation of a video transmitter as shown (right). Connect the lead from the power adapter to the video transmitter harness. Connect the power adapter EC3 plug to the power lead from the flight controller. Thread the video camera connector from the FPV compartment, through the fuselage and to the front of the bottom compartment. Attach the video transmitter antenna to the video transmitter. Replace the video transmitter hatch by gently pushing in on the sides and pressing the hatch straight down into the fuselage.
Flight test
The main feature of the convergence vtol is that these two flight modes (stability and acro flight modes) give you a wide range of performance for every phase of flight. You can make transitioning in flight.
To transition to airplane flight from multirotor flight, change the flight attitude switch on your transmitter to the airplane flight position. The throttle will increase slightly and the motor nacelles will rotate forward in three stages to the airplane flight position.
To transition to multirotor flight from airplane flight, reduce the airspeed, change the flight attitude switch on your transmitter to the multirotor flight position and stability mode for landing.
Features
- Cutting edge technology,The convergence vtol combines multirotor,fpv,plane versatility.
- Assembling the convergence VTOL is quick and easy, even you have never builded a drone or plane before.
- Transition to stability mode is smooth and flawless. Transition to acro mode worked great as well.
- Can flight both at the flying field and in indoor house, have no mishaps.
- Very easy to fly and stable in the wind. Unbelievable power.
