This is a walkaround of a Techone Angel that I modified to make it a light weight FPV platform. I've had the angel for about two years now and has served me well but now it is very badly beaten up and is looking worst for wear! I had used it a little for FPV but the fuselage wouldn't fit all the electronics nicely. I set about changing this and it was very simple, I cut the fuselage sides off and layed down balsa sheets to mount all of my equipment on. Yes, it will make it less aerodynamic but this thing has drag built in any way on the ailerons! However, the modification was really easy and this plane is great for light weight FPV with its low speed characteristics and vertical capabilities!! If there is enough want I may make a build video but im not sure as its really easy to do. I didn't really explain in the video but the reason behind the change was to give a lot more room for fpv, and to allow for easy changing and upgrade. Thanks for watching and if you enjoyed it check out our other videos on youtube and please subscribe!! Youtube channel- TheRCMentalists
http://tuntasbersih.com
http://obatPfizersurabaya.com
