My Homemade 5.8Ghz Circular Polarized Antenna's
I have reacently made a cloverleaft and a skew-planar antenna. i have a few tips as well.
When i was testing these antennas on the transmitter, after 5 min or so it had hardly changed in temperature, where with the stock antennas the transmitter would get warn(change in about 5-15 degrees celsius(49 - 59 degrees Fahrenheit.). the reason why i think the transmitter doesn't get hot is because the SWR is lower than the stock antennas( i don't have a SWR meter yet but hopefully i will get one (when i do i will post another artical about it)) so this means that the TX shouldn't get hot from the reflected RF power.
This is my cloverleaf
This antenna goes on the transmitter(TX)
This is my skew-planar
This antenna goes ont the receiver(RX)
Tips about building:
- when measuring the length of the copper lobe make the distance a little longer like insted of 52.65mm (or something else) cut it to 53mm because the wire cutters aren't always on the edge of the cuters they are usually around <1mm.
- same with bending the wire, make it a little bigger (not too much bigger other wise it wont be accurate.
- also if you are not sure just play around and cut one then meaure it and if it is shorter then increase the lenght and then go back once you have cut it and measure the actall distance.
- once you are happy with the lobes dip the tops in paint like i did. They look nicer and won't oxidise.
- it is easier to get a premade cable but i crimped the cables myself.
- i used sf- 142 which is a higher quatilty than rg 142 wich is better the rg316 (less loss in the cable)
Cable
it is quite hard to se but it says "SF-142"
Here is the data sheet : SF-142
these antennas are much better than the standard liner antenna(stock)
i am using the foxtech fpv reciever, so i need a Rp-SMA
here are the connectors
here are some more photos
A youtube video might be coming out later of the fpv test comaring to the stock antennas
The specs on that coax are good in fact like you said much better than most in fact a great choice. (http://disti-assets.s3.amazonaws.com/cdmelectronics/files/datasheets/4719.pdf link to spec sheet) You are also correct about transmitter efficiency. the better the antenna the more effective radiated power from the antenna you will get. you can also change the wire diameter of your elements which can also effect center frequency and bandwidth increasing/decreasing performance.
Keep up the good work.
