News just in - there's a new Gremlin out! The new Turbo Gremlin is a 3" race quad capable of some serious moves and some pro-level performance. Recently, two were put through their paces in a rather cold environment. Here's what happened:
About the Gremlin
This quad is a 2 to 3 inch Gremlin. Right out of the box you get a ton of quality components to put your new speed machine together. Matt Nowakowski has been racing with this same setup for a good while now and putting in some impressive performances. Matt is one of our expert quad builders here at the shop, so your new Turbo Gremlin can be put together by a pro! If you would rather not spend the time building and tuning your new gremlin, let us do the hard work.
Spec
The Emax 1106 6000kv motors have a real punch whether you're using 2 or 3 inch props. There's a reason why we called it the 'Turbo' gremlin! Chuck in a F4 flight controller with OSD, 4in1 28amp continuous current ESCs and a 40ch 5.8ghz VTX that can do 25/100/200 and 350mw AND a RunCam Micro Swift 2 and you have yourself quite a machine! All of these components can be included in your kit if selected. Talk about an all in one package.
The frame itself was designed with durability and longevity in mind, in spite of the high speeds that the machine is capable of. We want you to have the best experience, so making sure you don't damage your quad easily is key. Flying with confidence is all part of maximising your fun and your experience in general.
Inside the Box
1x Sidewinder Edition Frame 4x Emax 1106 – 6000kv motors 2x HQ T2.5x3.5x3 Purple Props1x HGLRC FULL Stack XJB F428-TX20.V21x RunCam Micro Swift 21x FT 2.0 Hex 1x FT 1.5 hex1x XT-30 male w/ 40mm lead1x Single JST Male Connector w/ leads1x FT Logo StickerRecommended Spec
-11XX series motors
-20x20 HGLRC Stack
-RunCam Micro
-3cell 650mah-850mah
-2”-3” propeller
Support the World of Flight with Your Kit
In case you haven't heard, we're currently running a campaign to fund the next steps of Flite Test. If you're thinking about buying a Turbo Gremlin, now is the best time to support us. Choosing to purchase your kit through the fundraiser will not only entitle you to the role of Founder to our new HQ and all the perks that go with it, your generosity will count towards establishing an exciting new phase of Flite Test history.
We hope you check out more about the new Turbo Gremlin. To make it easier, we've added some links below. These new quads are a total blast and we hope you have as much fun as we do!
Links
Pick up a Sidewinder frame here
Check Out All of the Other Gremlin quads Here
Support the Future Home of Flite Test Campaign
Article by James Whomsley
FliteTest.com Editor
No Comments Yet
Be the first to leave one!
