So Im building a new fpv setup that will fit n my backpack but im worried about the tramitters sticks getting bumped and beaten in the bag with the other gear or peircing a battery .
So i made this . i saw it in a picture while looking up ground station designs and thought it was an awesome idea
so to make this you will need
velcro thats not self adhesive
and some self adhesive velcro
and a pool noodle
so first cut the pool noodle so that you have two rings that are slight than your sticks . a bread knife cuts the noodle realy nicly .
next cut 4 small rectangles about 25 x 15mm from the hooky self adhesive velcro
then cut 1 small peice of 25 x 15mm from fluffy self adhesive valcro
then 1 long strip about 150mm long and 25mm wide from hooky non adhesive velcro
then 2 peices of fluffy non adhesive one 150mm and one 100mm
now sitck 2 small peices of hooky velcro oposite each other on on ring
then stick one of each of the small peices oposite each other on the other ring
now stick the last small peace on the back of the long strip of non adhesive hooky velcro
now lastly stick it all together and trim the 100mm peice so the sticks ar in the centre of the holes
They also can be worn as awesome goggles !
