I have been trying all the fpv channels to find the one I like the most well I may have it here I'll let you be the Judge here. In this clip I'm testing range and also the area's where I fly that are known problems. I'm using the 1.2-1 watt system with a Vee antenna on the Plane tuned from a 900mhz I had laying around. The receiver has a boasted whip nothing fancy. The Plane is the Sky Surfer Pro I like it cause it comes matched to a 4-cell drive system for longer flights and faster climbs, moves on well or flip the flaps on and creep around for good shots. The radio for this one is the 72mhz Futaba 7-C with flaps and spoilers on the three way switch and alirons on channels 1&5. As you will see the 72mhz gets more range than the 2.4mhz.
