Learn how to wire your own ultra-bright SMD LEDs in your plane, car, etc.
In this video I explain how to wire your own LED in your RC vehicle to your receiver. I first explain how the system works and then give you step-by-step instructions to do it.
Video Outline
- Intro - 0:00
- Parts List - 1:12
- --1. LED
- --2. wire
- --3. male servo connector with wire
- --4. resistor
- --5. heat shrink
- Tools List - 4:41
- --1. soldering iron
- --2. solder
- --3. tweezers
- --4. wire strippers & cutters
- --6. helping hands (optional)
- --7. blade
- --8. heat gun
- --9. multi-meter
- Let's Make It - 11:26
- --Step 1: Cut wire to length
- --Step 2: Strip running wire
- --Step 3: Prepare servo connection
- --Step 4: Cut and put on heat shrink
- --Step 5: Solder servo connection to running wire
- --Step 6: Connect resistor
- --Step 7: Strip other end
- --Step 8: Solder LED
- --Step 9. Test LED circuit
- Final Thoughts - 22:21
LED resistor calculator: http://led.linear1.org/led.wiz
Thanks!
