HOW TO IMPROVE PITCH CONTROL
This article is about increasing pitch control (elevator) for a Dual Aileron/Flaps plane.
The basic principle is to mix in the ailerons with the elevator to increase the effectiveness of pitch control.
Step 1 (applies to Spektrum programming )
Plug one aileron lead into the Rx "AUX" and one into Rx "ailerons".
Step 2
under WINGTAILMIX , set DUALAILE to active ( ACT)
Step 3
Create a new mix under MIX 1
ELEV -> FLAP
RATE D + 40% U + 40%
Increase these numbers to increase pitch control, reduce if too sensitive
This will work with other programmable radios however I am unsure of the set-up. The basic principle is to have the ailerons/flaps go down as the elevator goes up and vice versa.
NOTE
It is the difference of lift between the wings that creates a pitching moment, it is not dependant on the centre of gravity, it is only the difference that matters.
It requires no physical modifications so is "free" to do however has pros and cons.
Pros -
Much more effective pitch control.
Faster pitch change (as there is no lag time waiting for the angle of the main wing to be changed , this is very minor and takes place in milliseconds, but with floppy wings can be noticeable ) .
Effectively "free" as nothing new has to be built.
Will work even if the tail plane is stalled, in the case of high angles of attack the tailplane can become stalled causing "death spins", common in T-tail full size gliders and many 3D models.
Cons -
Effectively reduces the aileron control (roll control)
Requires a radio capable of mixing , such as the Spektrum dx6i and above.
Final
For this i used a "V-trainer" 4ch version from flyingwings. The Red one is my friends (3ch) which is his first plane. They are great to learn on, great for Fpv and are easily modified (and crash resistant).
http://www.youtube.com/user/ehandford?feature=mhee
