This week on the Flite Test Community Spotlight, we're showcasing Jackson Tenhave's balsa Bloody Baron build.
Quite a tongue twister, this balsa Bloody Baron is a new take on one of our popular FT foam board airplanes, originally a community designed model created by our good friend Dan Sponholz. We love highlighting talent on the Forums and this 'backpack' mod is one of these great projects that simply needed to be shared on the main site.
This plane can be fully broken down to fit into a backpack. This would be great for hikes and trips where you need your plane to be as compact and portable as possible.
The wings are held on with elastic bands whilst they are pinned together with two popsicle stick spars.
The Build
With ribs, formers, spars and fuselage sides cut out, Jackson's new project could get underway!
Jackson says that the fuselage was the first part of the build that he decided tackle.
"I built the fuselage today. Normally I just cut as I go, but this time I decided to cut all the pieces first to make the assembly quicker and even more fun!"
There are a few changes to the scale of this Bloody Baron. The wing was increased to 24 inches and made in two pieces. This was done to make the aircraft fit into a backpack if needed.
"I don't really have any need for a backpack-able plane, but I like to challenge myself in design. I also made a removable rudder to make it easier to transport."
Together, the wings look very well made! Popsicle sticks were used as wing spars/joiners for the two sections.
After a good sanding, the airframe was covered with covering film.
The airframe was finished by installing the electronics and hinging the control surfaces. The hinges were simply made from covering film.
As with the original Bloody Baron, the Balsa Baron has throttle, elevator and aileron control. However, it also includes a rudder. Two 5g servos located at the middle of the fuselage are used to move these surfaces.
The Finished Airplane
I think you'll agree that this model looks fantastic. Those covered wings with the light shining through should be a great sight in the air.
Test Flight
If you want to see if the statement 'balsa flies better' has any truth to it, check this flight video out. We think it looks pretty darn great! Nice one Jackson!
FT Bloody Baron
Get your own FT Bloody Baron from the Flite Test Store today!
If you enjoyed this article, make sure to give it a thumbs up so others can find it too!
Share what you’re working on!
Write an article for Flite Test
Share on the Flite Test Fans Facebooks Group
Article by James Whomsley
Editor of FliteTest.com
Contact: james@flitetest.com
YouTube Channel: www.youtube.com/projectairaviation
Great article though besides that 👍.
Bob
