There are so many requests about my flying wing plan which optimize one sheet foam board and only require some simple straight cutting and bevel. I have share the plan v1 and v3 (my v2 is not success yet) on flitetest few months ago. I found that the v3 is the most popular since it get more feedback than the v1, but personally I prefer v1 for daily use, because the v3 actually prepared for the high speed application.
Ok let me summarize the different of both version
V1
- Require more technique
 - More wingspan (41”)
 - Less swept
 - More glue required
 - Little bit hard to trim (on maiden)
 - Suitable for slow-medium speed
 - Here is the article of v1 and here is the CG v1 documentation (size is in mm)
 - Here the action of v1
V3
- Less technique required
 - Less wing span (36”)
 - More swept
 - Less glue required
 - Slightly easier to trim
 - Suitable for high speed or extreme one
 - Here is the article of v3 and here is the CG v3 documentation (size is in mm)
 - Here the action of v3
I hope this article is helpful
