Well, this is an interesting plane.
Specs:
| Wing Span | 1400mm |
| Motors | 480 size (1100kv) |
| Props | 9x6 3-Blade |
| Recommended Battery | 2200mAh 3S LiPo |
| Channels | Throttle, Ailerons, Elevator, Rudder, (optional) flaps |
There is a reason why we are skittish around Dynam planes. We have noticed a lack of quality throughout their aircraft that we have bought. They are a cheaper plane for a reason, and this plane presents that theme to us!
When unboxing the plane, it did not come in a model foam container to help reduce the risk of damage during transportation. However, this plane is packaged in boxes with no protection.
While assembling the plane, the manual was terrible and needed a lot more work. When we took a look at the motor, we noticed the motor shaft was undersized. This could easily bend on a bad landing. The nose gear was poorly glued and actually came loose during a landing. We are not impressed with this plane. The glue they supply is not good, and we suggest getting better foam glue to use.
To see more details about this plane. Please watch the video.
The hard part about telling people about this plane is the way it flies. It actually flies well. My other experience with a similar model from Eflite is during landings it bounces a lot. This plane did not have those issues. Overall, the plane flies pretty well.
