Hi FliteTest community,
The Mini Guinea is my very first FT Speed build kit. I picked the Mini Guinea because it is high wing witch means that it will be easy to fly, it's a twin engine plane(I already had a single engine Cessna so I wanted to try something new), and it has a cargo door so I can drop parachute guys, toothpick gliders, ect.
That being said, lets get started!
To start I soldered bullet connectors on to the motors and ESC's.
Next, I put together the mini power pods. Since this is my first time building the power pods, it took to between 45-60 minutes which is kind of a long time..
After the power pods, I got up the FliteTest Build video and started building the the wing.
The Build video can be found Here.
Next, I folded the wing over to make a nice air foil. I also installed the aileron Servos.
Then I made the things that the power pods sit in and install them on the wing. Then I put the motors on and connected all the the wires.
Then I built the body and the battery platform. You have to make sure the body is perfectly square.
Then on to the nose and tail!
I attached the nose to the body and installed the elevator and rudder servos.
Lastly, I plugged all the wires in to the receiver and put on the wing.
I had a very fun time building the Mini guinea and definitely recommend you get one. Also Keep a look out for articles on my maiden flight and how to add a cargo door!
If you want to support FliteTest and you want to build the mini guinea, head over to store.flitetest.com and search "Mini Guinea".
Also, Please subscribe to my youtube channel: CrazyFastFlying
Have fun building your FT Mini Guinea!
