the raptor is really a nice glider,of course you've to forget about the stock crap it come with...just change the servo for metalgear one,the motor now is ntm 35/36 1450kw,60 amp esc and 9x6 prop,and i made the elevator 3/4 inch longer,to make short take off ...this plane can make really quick manovre with right combination ailerons/rudder,fly nice inverted too,you just need a big area to do those kind of stunt.....is really crash proof....the plane fall streight into the ground with full throttle after a esc failure from more then 1000 feet and i had minor damage.....so really if you're loocking for a solid fpv platform is one to go....in the near future i'll buy ardupilot+osd and googles to make safe fpv experience,for the moment I'm using 7inch moinitor with no osd and no autopilot,i try to keep the plane under 1km....this time I just record the video without doing fpv...I hope you enjoy
Plane set up :
ntm 35/36 motor,60 amp esc,9x6 pusher prop,metal gear servo,kk2 with openaero2,5 v bec,900mhz 400 mw VT/R,cloverlea/skew-planar,sony cam with wide angle,gopro,few 4s battery and open lrs 433 mhz tx/rx with dipole antenna for rx and 433MHz Nagoya Dual Band Antenna on tx...now just need to decide what a OSD system or a ardupilot +minimosd....is not cheap get in FPV,but when u try u can'T stop.....
No Comments Yet
Be the first to leave one!
