This is a very simple under camber style airfoil for small to medium size planes, here are steps to build it:
first get your dollar tree foamboard ready, I like to clamp my foamboard down to the table so it doesn't slide around when I work this also flatens out the foamboard.
next mark dots at 4-1/2'', 6'' and 10-1/2''
then draw lines down the marks you just made
you'll need to make score cuts at the 4-1/2'' mark, the 6'' mark, and a full cut at the 10-1/2'' mark
then gently slide a popsicle stick down the two score cuts, this will crimp down the foam and make it easer to bend
next flip the foamboard over and if you look closely you'll see two small lines where you made your score cut
next cover the lines with packaging tape
Now you're finished! this is a great airfoil for all slowflyers because it gets tons of lift. This wing will work great with a Taylorcraft or Piper Cub style plane.
here are some other pictures:
