FTScratchBuild
Josh takes you step-by-step through how to build the new FT Simple Cub! As always, it is highly suggested to watch the video as you build.
Power Pod
- Assemble power pod. Cut holes to help route ESC. Clear out cavities.
- Make A-folds and reinforce with hot glue. Make sure both sides are nice and square (90 degree angles).
- Install firewall with hot glue (hold 30 seconds). Reinforce with tape.
- Put tape on tabs. Open holes with barbecue skewers.
- Assemble motor. (Watch video for details.) Don’t put on the propeller just yet.
- Mount motor onto powerpod on firewall.
- Mount ESC on bottom. Test the servos in manual mode. Make sure it spins counter-clockwise.
- Pass battery connectors and ESC wire into powerpod.
- Center control horns. Watch video for details
Wing
- Open up cavities and remove. (See video for details)
- Center spar: Make A fold with hot glue. Glue foam to foam, not paper. Repeat on other side of spar.
- Make C fold with hot glue. Repeat on second wing.
- Cut 45 degree bevel on first wing. Repeat on second wing.
- Attach both wings together with tape. See video for details.
- Glue in crease. Remove excess foam.
- Pop out aileron holes.
- Attach spar with hot glue.
- Contour wings and begin to fold over. Reinforce with hot glue. Watch video for details.
- Create dihedral for wing. Use dihedral gages. Reinforce with hot glue. Reinforce with tape. Watch video for details.
Fuselage
- Clear out cavities for folds. Watch video for details.
- Glue doublers.
- Establish crease line on back edge.
- Make B fold with hot glue. Watch video for details on where to put hot glue. Repeat on other side.
- Install bottom plate with hot glue.
- Install windshield and nose. Watch video for details.
- Install front cowling area.
Tail
- Bevel elevator and rudder. Reinforce with hot glue. Watch video for details.
- Install tail on to airplane.
Servos, Push rods and Control Horns
Install according to video.
Final touches
(Watch video for details)
- Make and install landing gear.
- Install wing.
Buy your own FT Simple Cub speed build kit here!
Check out the FT Simple Cub plans here:
FT Simple Cub
FT Simple Cub Full-Size
FT Simple Cub Tiled A Size
FT Simple Cub Tiled B Size
Thank you to Dan Sponholz for making these plans available to everyone!
What's your favorite thing about the FT Simple Cub? Share your thoughts with us in the comments below!
Oh, another great model and videos by the way. I was hoping Andres was going to help Josh with this build.
Two 3/16" dowels with small pieces of foam board glued between them on each end.
Since it's foam board on both ends, it's the perfect size to slide into the stab, holding the elevator or rudder perfectly straight. Then I have two free hands to work with the glue and servo.
o i download?
The spec sheets for all versions show 38 inch wing span.
FT Simple Cub
What do these mean? Please explain.
I just want to build one.
Full sized is just that, one sheet for the entire plan, in case you have a large format printer or want to convert for laser cutter/CNC
A is the original 8.5"x11" paper sized.
B is for other countries that use 11" x 17" as their standard print size.
I think my next project will either be the Guinea Pig or the Sea Duck, both much more intense than this build.
Can I fly this cub with a 1100kv motor is it possible?
https://www.amazon.com/Officemate-Recycled-Heavy-Dispenser-96690/dp/B010CEH7BS/ref=sr_1_2?ie=UTF8&qid=1512592691&sr=1-2&keywords=Officemate+Recycled+2-In-1+Heavy+Duty+Tape+Dispenser%2C+Black+%2896690%29
Are the Simple Cub window decals available in the store?
A few suggestions for those who plan to build this plane: Make sure you've got your rates set to 60%. I had mine on full and I could not control it (and I've been in the hobby for awhile). Even with just rudder its extremely difficult to control it at full rates. I found 60% good enough for me. Also, don't take this thing off at full throttle (well, you can do it, but I don't recommend it). With my electronics (3s battery, 30A ESC, and 1100KV motor), full throttle is just too much power at take off. The plane creates so much lift that it will go straight up (vertical). If you've never flown a plane before, then this is not how I recommend you start out in the hobby.
Am I missing something obvious or do I have to solder a new connector to the ESC?
ya estrellado varias veces, en que puedo estar fallando, este hacion es entrenador??
خیلی گشتم نبود😑😑😑
How thick is the foam board? 5 mm?
Thank you
What am I doing wrong please? Should I cut a more angled bevel, or press the foam down before I bend it , or what?
