I've been working on an ambitious model rocket Space Shuttle. Here's what I took away from the experience.
Here at Flite Test, we love an ambitious project. Over the years, you'll probably have seen dozens of absolutely crazy builds on our main channel, such as our latest Airsoft Battleship Vs. RC Divebombers. Inspired by the Space Shuttle program, I've been making an independent project to launch a rocket-powered Space Shuttle, detach a shuttle glider, and return it safely to the earth. Here's what I learned.
Firstly, what happened:
If you'd like to see the video of the actual launch attempts watch the 'Part 4' video here. As a brief summary, the three attempts were made to launch this model space shuttle. The first and second failed on the same day due to a wiring issue. Embarrassingly only the small c-sized Estes rocket motor in the shuttle ignited. The larger d-sized rocket motor in the booster failed as the igniter shorted out on both occasions.
The third and final attempt saw both motors fire and the rocket took flight, however, not all went to plan. Due to a lack of aerodynamic stability, the Space Shuttle arced over and crashed into the ground. Fail. Although the rocket should have been aerodynamically stable, a lack of airspeed meant the fins simply couldn't keep the thing pointing skyward. Here's what the whole project experience has taught me.
1) Space Shuttles are complicated
Yep, no kidding. Everyone interested in space and spaceflight knows the real Space Shuttle was a hideously complex machine. Even boiled down to approximate model form, there's still a lot that's going on and a lot of pieces to go wrong. To demonstrate here are some things to consider when building your own shuttle:
- Off center thrust line
- Shuttle release mechanism
- Aerodynamic inbalance
- Ignition of multiple rocket motors
- Parachute for the booster and SRBs
- Suitable launch rig
- Shuttle glide characteristics
And that's just for starters. I knew this was going to be a demanding project, but the amount of work that ended up going into it really did confirm that.
2) Start simple then work your way up to bigger things
This is quite obvious, but the Space Shuttle project did show that building up towards bigger and more complicated model airplane projects is the way to go, rather than diving straight into something beyond you. Don't build a Space Shuttle if you've never built a Simple Cub (or something like that). I think this project was right at the edge of my capabilities right now; a few years ago, there'd be no chance I could have pulled this off, but in a years time I may be even better set for another go.
As many things as possible were simplified, such as the design of the foam board RC shuttle glider.
The number of things I needed to build or acquire for the project was more than I wanted. The thing is, this was a model rocket + RC plane combo! This means that you need RC batteries, rocket engines, a launch pad, launch controller, launch controller batteries, RX transmitter and more. Needless to say, there's a lot to think about.
Most of the stuff needed at the launch.
3) Test as you go
Throughout the Space Shuttle project, I tested different parts of the mission. The great thing about this is that early successes can be celebrated and potential problems addressed. For example, the orbiter itself was designed and tested in part 1 to see if it flew with good stability. Next, in part 2 it was dropped from an RC plane to see if it flew from high altitude. It's great to do this to keep motivated and I recommend it.
The plans I used to design the shuttle. Yep, this is the USSR's Buran, but it's pretty much the same spacecraft.
4) Failure sucks (but you should probably keep going)
As mentioned, this Space Shuttle didn't make it very far - but that's alright. Thing is, I know that (although one thing went majorly wrong), many things went right and I can try again. If you've got a project that didn't quite work, find out what went wrong and move forward. It might be worth putting in some more hours to get across the finish line.
Not an ideal result, but that's fine if something was learned.
Watch the whole series:
If you want to see this project in its entirety, check out these four videos.
Part 1
Part 2
Part 3
Part 4
If you enjoyed this article, make sure to give it a thumbs up so others can find it too!
Share what you’re working on!
Write an article for Flite Test
Share on the Flite Test Fans Facebooks Group
Article by James Whomsley
Editor of FliteTest.com
Contact: james@flitetest.com
YouTube Channel: www.youtube.com/projectairaviation
