Hey everyone!
This article is going to be a video series of the XK A1200 FPV powered glider! I do an unboxing, assembly and test fight! Over all, I think this is a great airplane for someone just getting started! It's easy to fly, slow and stable. The FPV camera makes it even better!
FEATURES:
- Full FPV setup right out of the box includes a 1080p resolution on-board camera, 5.8G image transmission function and 600mW AV 6 Channel transmitter
- Comes with 3D/6G, a gyro for increased stability and helps decrease the chance of a crash. Simply cycle between 6G (stable mode) and 3D (no control surface limits) by pressing the aileron stick to the lower left after activating the model
- Stable and sleek profile supports smooth, slow and controlled flights
- Aerodynamic profile with long wing surface supports good lift for soaring
- Rigid foam airframe comprised of EPO foam is resistant to crash damage
- Extended flight times (Up to 45 minutes!)
INCLUDES:
- XK A1200 with Gyro and 600mW FPV Camera 1200mm (47.2") Wingspan - RTF
- FTR Futaba S-FHSS Compatible 600mW AV 6CH 2.4GHz Transmitter
- 1080p Resolution On-Board Camera
- 2.4GHz Receiver
- 2S 7.4V 2000 mAh LiPo Battery
- 2S LiPo Battery Charger
- USB Charging Cable
- Owner's Manual
Wingspan | 1200mm / 47.2in |
Length | 895mm / 35.2in |
Flying Weight | 475g / 16.75oz |
| CG (Center of Gravity) | 55-65mm from the leading edge of the wing at the root |
Power System | 2212B-2380kV Brushless Outrunner Motor |
Electronic Speed Control | 15A |
Propeller / EDF | 6x2.5 3-Blade Pusher Prop |
Servos | 4x 4.3g digital micro |
| Landing Gear | No |
Battery | 2S 7.4V 2000mAh 20C LiPo (included) |
Radio | FTR Futaba S-FHSS Compatible 600mW AV 6CH 2.4GHz Transmitter (included) |
| Ailerons | Yes |
Elevator | Yes |
| Rudder | Yes |
Flaps | No |
Lights | No |
If you enjoy watching my videos, consider giving it a thumbs up and subscribe!
In the end, I think this is a great plane for someone to start with if they are interested in FPV. It comes with everything you need to start flying right away! I have links in the descriptions of the videos to where you can purchase this airplane!
Thanks for reading this article,
-Jeremy
No Comments Yet
Be the first to leave one!
